Add Duct To Main Trunk - HVAC - DIY Chatroom Home Improvement Forum
Old 11-16-2009, 03:53 PM   #1
Add Duct to Main Trunk
I am finishing my basement and I need to add HVAC to two of my rooms. Can I just simply run flex from the top of the main trunk line going up to the new rooms? The two new lines would consist of one flex duct with one register. I already have two seperate lines coming off of the main trunk to go upstairs. My townhome is 2 stories plus a basement. I just want to make sure I don't screw up the HVAC for the rest of the house.
naturalmystic is offline   Reply With Quote
Old 11-16-2009, 04:52 PM   #2
Yes you can . Add a return to the rooms also if possible.
Old 11-16-2009, 07:48 PM   #3
An old Tradesmen
Rewards Points: 7,760
It won't heat right, but you can do it.
Basements that get their heat from the same duct system as the rest of the house, have a common flaw. Hot air rises, and cold air falls. Along with the fact that the thermostat is usually on the first floor. So it doesn't know that the basement is Cold.
Might want to put in an electric heater or 2, besides the 2 new runs.
Old 11-17-2009, 02:25 PM   #4
Thanks for the help guys
how many trunk line and feeder lines Grandma Lewis HVAC 4 03-08-2009 06:07 PM
duct trunk diy site unixb0y HVAC 4 03-02-2009 05:37 AM
where to position the main trunk? drewhart HVAC 3 02-12-2009 02:16 PM
Furnace install in attic - Duct configuration hartkem HVAC 6 11-08-2008 05:46 PM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 02:33 PM
