Add Blocking To Stud Cavity For Return Air? - HVAC - DIY Chatroom Home Improvement Forum
Old 08-25-2013, 01:25 PM   #1
Rewards Points: 365
Add blocking to stud cavity for return air?
Ok been working on my upstairs bedrooms and have several project going at once. One of which is trying to determine why I have such poor airflow up there.
I have found that one of my air returns is routed through the attic and is essentially uninsulated and then on top of it has a hole so that will need to get fixed. The register that it originates from is just in a stud cavity of an interior wall which while not the best works. My question is that since the register is near the top of the wall can I and should I add blocking (and caulk) just below it to prevent pulling air from other cavities? Should I do the same for my returns that just go straight down except have the blocking above?
Here is a shot of the duct in the attic that I plan on replacing with a nice foil wrapped duct.
info2x is offline   Reply With Quote
Old 08-25-2013, 01:32 PM   #2
Rewards Points: 582
yes make that as tight as possible on all your returns so it pulling from just the area of its intended purpose...it will help..ben sr
Old 08-25-2013, 07:34 PM   #3
Rewards Points: 365
Thanks. That's what I thought but since I'm not exeperianced with HVAC I figured I would check first.
The Following User Says Thank You to info2x For This Useful Post:
ben's plumbing (08-26-2013)
Old 08-25-2013, 10:07 PM   #4
Registered User
Rewards Points: 526
http://www.buildingscience.com/docum...39-five-things
http://www.buildingscience.com/docum...ong-from-start
Gary
Steel stud tip - use washers for blocking and new work brackets Dorado Building & Construction 0 05-06-2013 01:10 AM
The Correct Blocking of Knee Wall Stud Bays That Meet a Sloped Roof Lascaux Insulation 6 07-04-2012 11:09 PM
stud wall cavity 7echo Insulation 1 06-13-2012 09:34 PM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-05-2009 11:02 PM
Stud Blocking behind cabinets?? dirtmcgirt79 Remodeling 7 06-18-2009 08:06 PM
