Adapting Round Duct To Square Media Filter? - HVAC - DIY Chatroom Home Improvement Forum
Old 04-16-2011, 12:17 AM   #1
Adapting round duct to square media filter?
Hopefully an easy question - what is the best way to transition my two 16" dia flex return air ducts to two 20x25" media filters I plan to mount to the return air plenum? Do I need to have a sheetmetal shop fabricate transition fittings, or is there some off-the-shelf item that I could use?
lyonkster is offline   Reply With Quote
Old 04-16-2011, 10:14 AM   #2
An old Tradesmen
Rewards Points: 8,234
While sq/rectangular to round is a stock item, not all places will have the size you want. Might be best to just have the size you want made to the length you want.
Old 04-16-2011, 11:33 AM   #3
Thanks beenthere! Would it be too crude to use a 20 x 25 x 4" sheetmetal return air box (my supplier stocks these) and just make a 16" round opening in the face and attach a starting collar and a duct to it? It would not be much of a "transition" obviously, more like an "adapter"...
Old 04-16-2011, 01:04 PM   #4
An old Tradesmen
Reduces air flow when that is done.
Old 04-16-2011, 01:42 PM   #5
Yup, I figured that . I'll see what I can round up from the sheet metal shop. Thanks!
furnace filter fit?? Doug7852 HVAC 4 04-01-2011 10:45 AM
Going from 1 inch furnace filter to 5 inch furnace filter. BorgVilla HVAC 11 01-24-2011 04:17 PM
EAC or Media Filter? BlueBSH HVAC 11 05-02-2010 06:27 PM
Return Air Vents stubits HVAC 149 04-21-2010 04:50 PM
Need help Duct Sizing. Cyon HVAC 2 07-23-2008 08:15 PM
