Adapt Plenum - HVAC - DIY Chatroom Home Improvement Forum
Old 09-22-2009, 08:22 AM   #1
adapt plenum
I am replacing an old oil furnace with a new high efficiency natural gas furnace. The plenum on the oil furnace is 19"x20" and the outlet on the new furnace is only 16"x14". Can I adapt the larger plenum to fit the new furnace and will this be an issue.
Also any ideas on how to adapt the sheet metal plenum would also be helpful.
mdm75 is offline   Reply With Quote
Old 09-22-2009, 10:56 PM   #2
sktn77a's Avatar
Rewards Points: 390
Yes, you can do this if the plenum is larger than the funace (but not the other way around). The furnace manufacturer may make a transition adapter for the furnace but I suspect you'll need a custome fabricated transition to match up the dimensions exactly.
sktn77a is offline   Reply With Quote
Old Return air plenum for new furnace? Chemist1961 HVAC 1 12-25-2008 11:20 AM
Attaching plenum to furnace. hartkem HVAC 6 11-10-2008 03:17 PM
Removing Extended Plenum Calm_Blue_Ocean HVAC 15 01-07-2008 06:22 PM
Plenum - Where to buy? zootjeff HVAC 1 07-11-2007 09:21 PM
Plenum Design winkydink HVAC 1 11-22-2006 11:28 PM
