Accumulator Sweating Bad - HVAC - DIY Chatroom Home Improvement Forum
Old 09-20-2011, 07:03 PM   #1
accumulator sweating bad
Should a accumulator sweat instanly an water leaking out other then drain.If no what would cause this. Got good air flow.Low side 120 high side 320. 410 freon.Package unite.Thanks in advance.David
daboddie is offline   Reply With Quote
Old 09-20-2011, 07:37 PM   #2
Anything that's colder then the dew point is going to sweat. No idea what you're talking about with the water leaking out statement. Leaking out of what, the condensate pan?
Old 09-20-2011, 08:25 PM   #3
the sweating is not going to pan.It going to bottom of ac and where the metal is screwed to fram the water is going in between metal an floor of ac an the concret pad is wet all over
