Access Panel - HVAC - DIY Chatroom Home Improvement Forum
Old 10-18-2008, 04:52 PM   #1
Access panel
I have a comfortmaker furnace. How do I get the burner area access panel off? It has a small viewing window in what I believe is the panel, but removing the sheet metal screws won't get me there.
Chuckl is offline   Reply With Quote
Old 10-18-2008, 06:28 PM   #2
Why do you want to pull the cover off?
Is this a 90% furnace?
hvaclover is offline   Reply With Quote
Old 10-19-2008, 10:09 AM   #3
Burner won't stay on and I want to check the flame sensor. It re-cycles ok to the point where the burners ignite, then goes out. I think it's a 90
Old 10-19-2008, 10:18 AM   #4
0%0
OK I can help. I know the brand and still rep it. Tell me how old it is.
Comfortmaker made an 80% and a 90% with an enclosed burner.
The 90 vented out the side wall with PVC pipe. The 80 vented with metal pipe into a chimney.
Now that that's out of the way tell me how it's acting so we can be sure we are going in the right direction.
I know you Say burners won't say on but there are other ting that cause the same symptoms.
Old 10-19-2008, 10:33 AM   #5
Thanks for your time....It vents out the top into a chimney...must be an 80?
Don't know how old it is. I've been here 5 years and it wasn't new when we moved in.
It's cooled off here and we tried to get the chill out of the house the other day. We turned the thermostat from cooling to heat, turned it up about 10 degrees and waited. Nothing happened so I checked the furnace for a pilot lite (shows how old I am), but it has an electronic ignitor. There is a blower that comes on in the gas valve area and stays on. I turned the thermostat down, shut off the gas supply and turned off the power to the furnace to recycle it, and waited about 5 min. Turned gas on, thermostat up and power on, and that's when the burner tried to ignite for a few seconds and went back out.
Old 10-19-2008, 10:43 AM   #6
Ok, turn furnace off by the light switch on the side.
Set thermostat as high as it goes.
Look into the burner window and turn on power.
The inducer should come on and after a while you should be able to see
a red glow in the burner.
Note if burners light, describe how they look before they go out.
Burners should be mosly blue with very littel yellow or orange.
Old 10-19-2008, 12:17 PM   #7
I did what you said. The induction motor came on, and after about 10-20 sec. the ignitor glowed orange followed by the burners coming on. They stayed on this time and had a blue uniform flame and after 10 sec or so the furnace blower came on. Hoping against hope that it may have returned to normal, I let it blow for several minutes and turned the temp down to kick it off. One lunch break later I tried it again . Induction motor on, orange glow on for a sec, then burners on for 4 sec....orange glow off, burners off. It recycled 2 more times with similar results.......HELP
Old 10-19-2008, 12:35 PM   #8
I am here to save the day
You already have the screws. What;s holding it tight is the rubber gasket.
Grab the right side with the finger tips of both hands and pull out.
Don'T be afraid to coax it with a putty knife or flat head screw. The heat of the burners makes the gasket sticky but it will come off. It's a good fit that makes it a little hard to remove also.
Let me know when you get the cover off.
Old 10-19-2008, 12:45 PM   #9
In your opinion, would you be thinking flame sensor?
Old 10-19-2008, 12:53 PM   #10
That or a combustion disc.
Clean the sensor first if that does not do it then we dig a little deeper.
BTW, do you have a meter that measures micro amps DC?
Old 10-19-2008, 02:19 PM   #11
I got the panel off after some arguing with it, but from where the sensor is located and the igniter is hooked in, I've decided my old bones no longer bend that way, so...........time to call a pro. Thanks for your help.
Old 10-19-2008, 02:28 PM   #12
Don't be a wuss! You got it 3/4 licked.
I ain't no spring chicken neither.
Holding that sensor is a phillips head screw. Get you a long snank no2 and un -screw the sensor and clean it with an SOS pad.
Old 10-20-2008, 01:11 PM   #13
Thanks again for the help. The *pro* got here this morning and fixed it. The flame sensor was ok, the ignitor checked ok, but...the control module needed replaced. He said that furnace is 20 years old and eventually will shoot craps, but for now I guess I'll keep pushing it. Thanks again.
Access Panel or Door for Shower Plumbing Any pics? twilightcall Plumbing 4 12-22-2009 05:53 AM
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 02:37 AM
Apartment - Access to Panel Box? silver26 Electrical 3 08-07-2008 09:56 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
