Access To CPC13H Evap Coil.. - HVAC - DIY Chatroom Home Improvement Forum
Old 06-27-2008, 12:08 AM   #1
Access to CPC13H evap coil..
A inspection showed a huge leak in the duct work so the coils will need to be cleaned. The unit is a GOODMAN GPC13H roof pack.
http://www.goodmanmfg.com/Home/Produ...8/Default.aspx
How do you access the evap coils for cleaning??
The sidepanel that the evap coil drain comes out of does not appear to be a good access point.
bginvestor is offline   Reply With Quote
Old 06-27-2008, 10:40 PM   #2
Ouch!That'll leave a mark
If you remove the top, you should be able to access everything. Indoor coil and the inside of cond. coil. Good luck
ridgevilleac is offline   Reply With Quote
Evap coil question merlinfolks HVAC 15 07-27-2009 08:20 AM
Evaporator coil for Goodman A/C leschuler HVAC 2 09-25-2008 01:43 PM
help, Poor performing AC, coolant leak? damaged coil? images maverick06 HVAC 5 07-31-2007 06:30 PM
Will a 4T Evap. Coil w/50' Lineset suck in 21 oz R22 at 500 microns? hennyh HVAC 1 02-21-2007 12:49 PM
