-   -   Access to CPC13H evap coil.. (http://www.diychatroom.com/f17/access-cpc13h-evap-coil-22859/)
bginvestor 06-26-2008 11:08 PM
A inspection showed a huge leak in the duct work so the coils will need to be cleaned. The unit is a GOODMAN GPC13H roof pack.
http://www.goodmanmfg.com/Home/Produ...8/Default.aspx
How do you access the evap coils for cleaning?? :furious:
The sidepanel that the evap coil drain comes out of does not appear to be a good access point.
ridgevilleac 06-27-2008 09:40 PM
If you remove the top, you should be able to access everything. Indoor coil and the inside of cond. coil. Good luck
