Is Access To Back Of Furnace Ever Needed? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-30-2012, 12:32 AM   #1
Is access to back of furnace ever needed?
Hi,
I bought a house about a year ago which has a somewhat finished basement. Right now there is the potential of accessing the back of the furnace by removing some in wall shelves, and a piece of plywood behind them. I'm thinking of removing the shelves, framing the opening, and dry walling over the opening.
Do I need to keep access to the back of the furnace for any reason or is it ok to seal it in?
ghostee is offline   Reply With Quote
Old 01-30-2012, 12:51 AM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
As long as theres roughly 6" of clearance between it and wall and your evap coil for your a/c doesnt stick out that way i wouldnt worry about it
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 01-30-2012, 01:47 AM   #3
Is that the way to get it in or out of the space? If it ever needs to be replaced, you'll want adequate access to get it out & a new one in.
hdpro is offline   Reply With Quote
Old 01-30-2012, 07:13 AM   #4
Rewards Points: 1,216
Most manufacturers build furnaces with 1" or 0" clearance in the back.
You shouldn't have to get back there for anything, I would check the model number of the furnace and look up the clearances for your specified furnace.
COLDIRON is offline   Reply With Quote
Old 01-30-2012, 09:10 AM   #5
plummen's Avatar
If you ever need to get to the back of plenum to take the furnace out depending on how it was installed those extra 5" might be nice to have
Old 01-30-2012, 10:13 AM   #6
biggles's Avatar
if you have AC with an A coil on top of that furnace the back is an access to cleaning it..standing in front of the furnace looking at the sheet metal box on top draw an A on it that is the position of the coil within..so the back would be to get in and clean it...
Old 01-30-2012, 11:32 AM   #7
"Been putting A coils in for 40 years never had to gain access to the rear, always through the front plate".
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Rheem 80% Furnace Short Cycling rlukas79 HVAC 0 12-19-2010 04:27 AM
Furnace Help Needed Jobethjen General DIY Discussions 2 12-18-2010 12:13 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
