Old 09-27-2011, 06:42 PM   #1
AC won't shut off
First time posting. I have Tempstar unit that won't shut off; continuosly cooling. I changed the thermostat (Since it was old) to a Honeywell programmable, but the problem persisted. I then changed the contactor on the outside compressor, but that didn't work either. I believe that the problem may be in the wiring of the thermostat, but I have triple chekced it; according the labels that were on the wires prior to moving in.
I'd appreciate any troubleshooting tips.
Rhemius76 is offline   Reply With Quote
Old 09-27-2011, 06:48 PM   #2
I'm Your Huckleberry
AC won't shut off
You did some thermostat work such as installed a new one or moved the old one and then this problem started?
Doc Holliday is offline   Reply With Quote
Old 09-27-2011, 07:04 PM   #3
AC won't shut off
It's easier for us to help you if you say something. I can tell you how to troubleshoot but I need to know where to begin. You've given me suspicion that you've done something to the stat wiring. Is this the case?
With the stat fan in the off position, is the inside blowing? Outside coming on as well? What exactly is happening? What's happening in heating mode, anything?
Old 09-27-2011, 07:07 PM   #4
AC won't shut off
My apologies for not clarifying. The problem began with the old thermostat. It needed to be replaced regardless, so I started the process of elimination there. But unfortunatly the problem continued and the air still doesn't shut off.
Old 09-27-2011, 07:12 PM   #5
AC won't shut off
Also to add: I am unable to use any functions in the new thermostat.
Old 09-27-2011, 07:12 PM   #6
AC won't shut off
So while the stat is set in the OFF position the system is running? Do you have a gas furnace or an electric air handler? I ask because a furnace will have a control board with low voltage terminals, like at the stat. You didn't work there as well, did you?
I need to know what is happening on each call, cooling, heating, fan ON and Fan OFF.
Old 09-27-2011, 07:14 PM   #7
AC won't shut off
Okay, we'll start from scratch as soon as I know whether you have a gas furnace or an electric air handler.
Old 09-27-2011, 07:17 PM   #8
AC won't shut off
electric. One half in the garage the other outside in Florida weather
Old 09-27-2011, 07:29 PM   #9
AC won't shut off
Okay, did you do anything to the wiring at the air handler or only at the stat?
Old 09-27-2011, 07:31 PM   #10
AC won't shut off
Only at the stat; but that was only after the problem started
Old 09-27-2011, 07:37 PM   #11
AC won't shut off
What I think you might have done is put the condenser "red' wire onto the R terminal, always feeding it power.
Old 09-27-2011, 07:39 PM   #12
AC won't shut off
Is it possible to take pictures of all of the wiring and post them? At the air handler and at the stat.
Old 09-27-2011, 07:51 PM   #13
AC won't shut off
I will check the installation of the thermostat (particularly the red wire) again and post in a little bit. Thanks for the suggestion.
Old 09-27-2011, 08:18 PM   #14
AC won't shut off
Its probably going to end up being the thermostat wire. After a number of years of being strapped to the vapor line of a heat pump, it starts melting..
Master of Cold is offline   Reply With Quote
Shut off boiler for the summer? secutanudu HVAC 2 08-01-2011 12:34 PM
No main power shut off vab53 Electrical 26 06-12-2010 03:51 AM
Shut Off Valve won't shut off DIY_Dumbie Plumbing 1 07-11-2009 03:22 PM
Community water shut off zevon Plumbing 14 10-03-2008 08:16 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
