Ac Wont Keep House Cool - HVAC - DIY Chatroom Home Improvement Forum
Old 07-10-2011, 03:11 PM   #1
Unhappy
Ac wont keep house cool
My downstairs AC won't maintain the set temp. The upstairs is cold and separated by bedrooms. Downstairs is fairly open. It blows cold air from the ducts. Checked duct connections all is fine. Felt supply lines and they feel fine. Washed off fins. Live in las vegas where humidity is usually around 13% this past week has been stormy with humidity at about 60-65%. Any suggestions would be helpful. Unit is a lennox
kmkiley is offline   Reply With Quote
Old 07-10-2011, 03:46 PM   #2
What is the temperature split between the cold supply air temp and room temp ?
clocert is offline   Reply With Quote
Old 07-10-2011, 03:58 PM   #3
I have the thermostat set for 78. The inside temp ranges between 80-81. during the day. at night it maintains the 78 setting
Old 07-10-2011, 04:00 PM   #4
Doesnt sound like a big deal but it means the unit is constantly on and running
Old 07-10-2011, 05:40 PM   #5
What is the cold air temperature that blow into the room from the register ?
Old 07-10-2011, 06:04 PM   #6
How would I check that?
Old 07-10-2011, 06:10 PM   #7
Rewards Points: 6,652
Go to the store and get a thermometer that goes below 0 degrees. Find them in the kitchen section at Bed, Bath & Beyond, Target, Wal-mart. Hold the probe end in the closes vent to the air handler, and then go to the farthest one. Mine runs around 44-48 degrees. My home stays around 72 during the day, 70 at night. 78 is way too warm for me, no matter where it would be.
Old 07-10-2011, 07:46 PM   #8
If you don't have the type of thermo mentioned by gregzoll, any thermometer will do, just put it within one inch of the cold air register and measure the air temp. I bet your air temp is somewhere between 60 and 80...( all we want to know is exactly how cold the air is)
Big water leak under house Puzzles Plumbing 4 04-27-2011 02:50 PM
dealing with exterior slope towards house. organick Building & Construction 26 03-19-2011 02:57 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
How cool should it be inside the house? beer_geek HVAC 8 05-13-2007 01:42 PM
