AC Wiring Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 01-21-2010, 08:45 PM   #1
AC wiring Problem
Hello,
i just moved into a house and the hvac wiring was torn apart I got most back to where i believe it goes. but I don't know where to hook up the red and white wire that come from the compressor. I am posting some pics to help.
i am not sure of the make or model all i have is this model # NUGG075DF02
But with some searching it turned no results. I am pretty family with electronic circuits and schematics but i could not find one. Any help is appreciated.
SLEDGEHAMMER84 is offline   Reply With Quote
Old 01-21-2010, 08:47 PM   #2
also i belive the unit was installed in 94 from a sticker on the outside of the furnace
Old 01-21-2010, 09:20 PM   #3
as seen on tv
Rewards Points: 150
compressor? are you sure you do not mean blower motor. Your pic are of a standard gen purpose relay!
qbert is offline   Reply With Quote
Old 01-21-2010, 09:23 PM   #4
I am referring to the wire that comes inside from the coil and compressor unit outside the house. Those red and white wires arent pictured because they are disconnected.
Old 01-21-2010, 09:28 PM   #5
as seen on tv
Rewards Points: 150
low voltage control wires from outdoor unit go to Y-C on indoor terminal block for a/c only applications.
Old 01-21-2010, 09:32 PM   #6
does it matter which to where?
Old 01-21-2010, 09:33 PM   #7
you said a/c only applications. It also has a furnace. does that matter?
Old 01-21-2010, 09:35 PM   #8
as seen on tv
Rewards Points: 150
Yes i meant with a furnace and a/c. color does not matter one wire on C one on Y
Old 01-21-2010, 09:39 PM   #9
Thanks I will try and post my results. Hopefully everything else is in the correct place
Old 01-21-2010, 09:50 PM   #10
Ok unit is turning on outside but now the blower motor turns off when it turns on. I had it wired this way yesterday and left it running hoping the blower would turn on but it never did and the line froze. any ideas?
Old 01-21-2010, 11:02 PM   #11
as seen on tv
Rewards Points: 150
sounds like you using the wrong contacts at the gen purpose n/c instead of n/o better take a closer look at the wiring diagram
Old 01-21-2010, 11:34 PM   #12
Ok, I found a HEIL badge that fell off the furnace. (if that helps) N/C? N/O? sorry I do not know what you are referring to. I am tracing the diagram now.
Old 01-22-2010, 12:13 AM   #13
After examining the schematic, studying the relay part; I moved the
black wire from pin#4 -> #1
violet wire from pin#5 -> #3
I am still unsure about the proper location of the black in the lower right and the white in the lower left.
The blower motor now remains on with the outside unit. but did not turn on untill i activated the fan manually on the thermostat. could this be due to a faulty thermostat? it is displaying the correct temperature.
Tags
air conditioner , furnace , wiring
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Wiring problem datoda Electrical 6 12-28-2009 07:43 PM
Problem with Air Handler wiring connection to Outdoor Unit & Thermostat miamikk HVAC 0 09-29-2009 07:02 PM
Switched receptacle wiring problem. sheshore Electrical 6 09-27-2009 01:37 PM
Outdoor AC on whenever heat is on - wiring problem? SammyLi HVAC 3 10-12-2008 12:29 PM
