AC Will Not Cool Properly On Very Hot Days. - HVAC - DIY Chatroom Home Improvement Forum
Old 07-26-2011, 11:48 PM   #1
AC will not cool properly on very hot days.
I am a issue with cooling the house when it is hot outside. I can get a delta T of 19/20 degrees during the night and cool days, but only around 14/15 on really hot days.
Therefore, when it is in the mid 90s, the house will not get cool.
I did the check right after the evap coil, so I canceled out my attic ventilation and insulation.
Head pressures and freon level are good and all filters and coils are clean.
Any other suggestions?
blarose is offline   Reply With Quote
Old 07-27-2011, 12:07 AM   #2
You said you get the delta T by checking the temp right after the evap coil, how about the other number ? did you get it from your rooms return register or right before the blower ?
clocert is offline   Reply With Quote
Old 07-27-2011, 12:11 AM   #3
right before the blower and actually the two numbers are only .5 degree different
Old 07-27-2011, 11:15 AM   #4
This is a hard one, unless something wrong with the condenser (old ?) . You may have to call a tech to check the pressure and/or SC, SH for you. Is the air flow OK ?
Deck Power Washed...now many days of rain before stain! mark2741 Painting 67 09-27-2013 06:32 PM
Any idea to cool down the 3rd level of my home? homenewbie General DIY Discussions 18 05-31-2011 11:02 PM
Crack in concrete 2 days after pouring? danreg99 General DIY Discussions 19 10-14-2010 09:00 AM
28 Days to lay tile??? tomptat Flooring 6 08-28-2009 11:43 AM
Size A/C system properly 70stang HVAC 1 03-26-2006 07:22 PM
