AC Unit Relay/Controller Board Fried - HELP!! - HVAC - DIY Chatroom Home Improvement Forum
Old 08-01-2011, 12:02 AM   #1
[Alex]
Exclamation
Hey everyone. This one is tricky.. any help would be greatly appreciated!
My home AC unit died about a month ago. It looks like a mouse bit into the electronics and got fried.. while also frying the relay/controller/circuit board. The system was made by a company called Vent-Aire Systems (Model ECS45M COMFORT SYSTEM). They are no longer in business & I can't find parts anywhere.
The only number I can make off the relay/controller board is CB18. It has relays attached to it and a 6 pin & 14 pin connectors on one end. Half of the board is fried and so are 2 of the relays. I believe it's 110V.
Is there anyway to make a custom board? Are there generic boards out there anywhere? I have no idea where to look or how to get this fixed. I've called a few shops in my area and have gotten no help.
--Alex
alxsti is offline   Reply With Quote
Old 08-01-2011, 05:25 AM   #2
An old Tradesmen
Rewards Points: 6,140
I removed your link, No free advertising Alex.
Post pic of unit, it may have be a rebadged unit made by one of the larger companies.
Old 08-01-2011, 07:10 AM   #3
biggles's Avatar
try these brands eye ball it the brand you have is generic so it has to be used by others http://www.bestbuyheatingandaircondi...cuitboards.htm
Old 08-01-2011, 11:08 AM   #4
[Alex]
Whoops - sorry!
I'll try to get pics up later tonight. Thanks.
Old 08-02-2011, 12:22 AM   #5
[Alex]
I believe this powered a Magnetek motor, but (of course) they sold their small electric motor line to A. O. Smith. I think that this motor is A. O. Smith Stock #754.
A control board needs to control it plus kick on the circulatory pump for the domestic hot water heater that supplies the radiant coil for the back-up heat.
Here are some pics of the fried relay controller board:
(biggles - I looked through most of those manufacturers pictures, and can't match this up to any of them.)
Old 08-03-2011, 10:44 PM   #6
[Alex]
Any ideas? I talked to a local HVAC parts warehouse today and got no help. They suggested going to a computer place and have a custom board made.
Old 08-03-2011, 11:08 PM   #7
JJboy's Avatar
Anyone with basic knowledge in electronics can make the PCB board .... but trying to find the components first
http://www.radioshack.com/product/in...LAID=107594612
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 08-04-2011, 06:57 PM   #8
REP
I am totally unfamiliar with the brand of unit you mentioned.That said,the relays look familiar..
If you look up the manufacturer and call them they might be able to help you with the relays at least.
As mentioned before if you take the circut board to a good electronics store like Radio Shack,they might be able to point you in the direction of somebody that likes to rebuild old equipment.If you can find someone ,I'm sure they can help you.
Good luck and if you can report back to let us know how you did.
REP is offline   Reply With Quote
Old 09-02-2011, 02:41 PM   #9
[Alex]
Still using a window unit & have been unable to source the parts or skill needed to fix this.
Old 06-25-2013, 06:12 PM   #10
[Alex]
Update -- we ended up upgrading to an entirely new system. Costly, but hopefully will be trouble free for the next couple decades at least.
Old 06-25-2013, 06:30 PM   #11
An old Tradesmen
Hope it last a good long time. Thanks for the update.
Carrier furnace control board - OEM or ICM ? anku HVAC 13 10-12-2012 11:50 PM
GMP075-3, Bad Board?? RaySuave HVAC 2 12-12-2011 11:02 AM
AC condensing unit failure? Hotinsummer HVAC 3 08-09-2009 03:08 PM
luxaire/york 33109167000 furnace board replacement check HVAC 18 07-13-2009 11:03 AM
Coleman Split Unit Problems kyallendiy HVAC 4 11-04-2008 07:41 AM
