AC Troubles - HVAC - DIY Chatroom Home Improvement Forum
Old 09-04-2011, 10:24 PM   #1
AC troubles
We just bought a house, the air works but it just dont cool as low as I like. It will get down to 73 but just won't get any colder. I noticed the larger line from the outside unit to the wall of the house ( about 3 or 4 feet ) is not insulated, the rest of the line in the attic is insulated. Will that small amount of line outside uninsulated cause the unit not to cool proper?
Also we went into the attic yesterday, it was cloudy out and not bad hot but the attic was cool. What's the best way to locate leaks in the ductwork? There is about 6 inches of insulation in the attic, and the garage didn't have any insulation over it. Some people say if I put 6 more inches of insulation it would help the cooling issue. Is this true?
Thanks.
Pipelayer31 is offline   Reply With Quote
Old 09-04-2011, 10:30 PM   #2
Look for the wet spot.
Master of Cold is offline   Reply With Quote
Old 09-04-2011, 11:10 PM   #3
biggles's Avatar
make sure the supply truck off the air handler is sealed 360 degrees around...and the return duct is pulling only the grilled return...should have 18F drop on the return s the supply air
Old 09-05-2011, 08:25 AM   #4
An old Tradesmen
Rewards Points: 6,588
That little bit of uninsulated vapor line outside won't effect your cooling ability.
Yes, more insulation will help.
Make sure your air filter is clean, along with both your evap coil and condenser coil.
deadbolt lock troubles mindinmotion Building & Construction 20 02-23-2011 10:14 AM
Carrier Troubles - Fails to ignite- sometimes terrylueders HVAC 13 02-14-2011 07:48 PM
Carrier Troubles - Maybe bad Gas Valve terrylueders HVAC 1 01-20-2011 04:20 PM
Blower Troubles MsAngeliaS HVAC 2 01-04-2011 05:57 PM
paver troubles jbmh83 Landscaping & Lawn Care 2 05-23-2008 07:04 PM
