AC Stops Pushing Air After A While. - HVAC - DIY Chatroom Home Improvement Forum
Old 06-30-2013, 07:28 PM   #1
AC stops pushing air after a while.
Just installed a new AC. When i turn on the ac, the air flow out of the registers is good but then after 10 minutes, the air flow becomes very faint. Air does seem to be cool, but the lack of air Does not get the house cool. Any solutions?
jclee is offline   Reply With Quote
Old 06-30-2013, 07:55 PM   #2
Rewards Points: 79
Sounds like the coil is freezing. Check your filter and verify that you have the correct airflow for the size unit you have.
Ebierley is offline   Reply With Quote
The Following User Says Thank You to Ebierley For This Useful Post:
jclee (06-30-2013)
Old 06-30-2013, 08:56 PM   #3
I'm using those really expensive air filters, Lysol ones. Too see if air flow is the problem. Can I take out the filter temporary to diagnose the problem or should I avoid this?
Old 07-01-2013, 07:08 AM   #4
You can try it without the filter temporarily. It might not have enough refrigerant in the system also.
davenc is offline   Reply With Quote
AC stops cooling when it rains Emfuser HVAC 125 07-23-2014 12:44 AM
window stops Please help fast justneedanswers Windows and Doors 4 04-21-2012 12:09 PM
Burner always stops at LOW setting on L8124L pleasehelpmike HVAC 2 01-19-2011 08:22 AM
Extending finished attic insulation stops? Mitch H HVAC 2 12-09-2009 11:00 AM
Front Door - Door stops? 1655graff Carpentry 6 08-14-2009 12:40 PM
