AC Stops Cooling Well At Days End??? - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-24-2014, 09:05 AM   #31
Hvac Pro
yuri's Avatar
Rewards Points: 1,096
No. It all depends on literally how much air/heat is flowing across the evap coil. Ducts sizing, fan speed etc will change the evap temp/freon pressure. Also the return temp in the house. Very rare that people go below 70 F as that is uncomfortable for most people in my experience. The higher the return the higher the coil and supply temp. Also whether the unit is over or undersized.
The Following User Says Thank You to yuri For This Useful Post:
digitalplumber (06-24-2014)
Old 06-24-2014, 09:08 AM   #32
Rewards Points: 16
Thanks I was asking to clarify did not want anyone reading this to expect those numbers on their systems. Did not seem normal to me.
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 06-24-2014, 09:11 AM   #33
Hvac Pro
yuri's Avatar
Part of the issue is exactly where you stick the thermometer. Need to be a foot or more away from the coil and where it is reading air movement. Just like reading temp with a furnace you don't want to be close to the heat exchanger.
Old 06-24-2014, 01:45 PM   #34
Rewards Points: 6,652
2 tons for 821 sq ft? Now that is oversized unless Illinois is close to Texas in climate. 18,000 would be better. However with that ECM blower which can slow down a lot and a 2 ton unit you can be comfy and make it work and make ice cubes.
Basement added into that, makes it 1642.
It is actually very comfy as it is. I tried knocking it down a notch, from where it is set for the fan speed. It actually made things worse.
Old 06-24-2014, 03:34 PM   #35
Hvac Pro
yuri's Avatar
We don't AC our basements or add it to the load unless it is a walkout or half basement with large glass. Plus we insulate the heck out of the basement walls.
Old 06-24-2014, 03:44 PM   #36
We do not do that here, unless you plan on finishing the basement. Otherwise it is just bare concrete walls. Even if I finished it. I would still be fine with the setup.
Deck Power Washed...now many days of rain before stain! mark2741 Painting 67 09-27-2013 07:32 PM
brand new AC unit not cooling house yodiebear HVAC 4 10-09-2011 12:41 PM
Kenmore fridge stops cooling with frost in freezer donnoit Appliances 3 09-20-2010 08:59 AM
Wiring a Ruud RGTK-06E series furnace for 2-ton cooling bolo_invictus HVAC 3 01-25-2010 04:24 PM
Installation of Honeywell Thermostat - cooling function KDW Electrical 0 10-04-2009 10:56 AM
