AC Starting To Freeze? - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 09-09-2011, 04:02 PM   #31
Rewards Points: 640
Originally Posted by JJboy View Post
Evap coil is freezing due to low refrigerant or poor air flow. You need to check for leakage of refrigerant.
The drain line should be clogged.
even when it hasn't been running it can still freeze?
drain line from the coil's pan is clean, flushed it out and nothing but clear water came out at the rate I poured it through
BlueBSH is offline   Reply With Quote
Old 09-09-2011, 05:40 PM   #32
An old Tradesmen
Rewards Points: 6,074
If you have an 80% furnace, it could have come down from the chimney/flue.
Old 09-09-2011, 05:42 PM   #33
JJboy's Avatar
No, have you check if the condenser ( outside unit ) is running when you turn off at thermostat?
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 09-09-2011, 05:48 PM   #34
Rewards Points: 640
92.5% AFEU, pipes run horizonal to the outside
unit outside has been off also never ran in the past week
Old 09-10-2011, 03:14 PM   #35
Rewards Points: 640
ok..... this is just getting ridicilous... so while tracking down where the water came from, turned out they ran a 1/4" copper flex line through the extended plenum and it appears to of froze and burst enough to drip water right down the center of the A coil fast enough to get into the furnace....
who in their right mind runs a 1/4" copper flex line through a plenum... they must of fed an old humidifier from this line somehow because they just had it capped off
*rips out hair*
Old 09-10-2011, 06:09 PM   #36
An old Tradesmen
Old days, they would do that to help preheat the water before it went into the humidifier.
Old 09-16-2011, 09:16 AM   #37
Rewards Points: 640
yeah, now I am mad... guy came out to do the work, pushed all the refrig back into the outside unit, purged the lines, changed the orfice, pulled a vaccum on the line for hours (he wasn't there for that time) came back, finished up, must not of tested the darn thing (i wasn't home at the time to watch) because when I tried it out within 1 minute the darn line was froze again in the same spot after the orfice, and the A coil was iceing up within 15 minutes of running...... uuuuuuuuuugh
to top it off, I got charged $75 an hour for the 4 hours they wern't there but the vac was running on the line.... I seriously doubt it cost $300 to run a vac...
anyways, what in the world could be left as the problem?...
Old 09-16-2011, 09:29 AM   #38
JJboy's Avatar
If A-coil has an obstruction inside this problem will happen. Call the technician again. He will be able to verify this by checking the pressures.
Old 09-16-2011, 09:37 AM   #39
i think you need to get a pro out to fix. may be over charged noe. i dont know why someone would add 1.5lb of refer. the system should never!!! loose refer. either you have a leak or he added refer when you did not need it.
www.cascadehvac.com
cascadehvac is offline   Reply With Quote
Old 09-16-2011, 09:42 AM   #40
Rewards Points: 640
www.cascadehvac.com
these people are supose to be "pro's"...
system wasn't serviced since it was put in years ago... I think the system takes a 5lb charge? forget exactly, I thought 1.5lb was a lot but they looked at me like I was the dumb one when I said that's a good bit low...
Old 09-16-2011, 09:54 AM   #41
i blockage in the line makes sense. if for example the indoor txv is blocked, the pressures would read like it was low...he would then add refer trying to get the pressures to go up. also liquid lines will freeze at the blockage.
Old 09-16-2011, 09:57 AM   #42
Rewards Points: 640
that's why they originally wanted to replace the orfice since it was freezing right at it... they thought it was blocked there... its now replaced and same issue, freezing right at the same exact spot
Old 09-16-2011, 10:05 AM   #43
JJboy's Avatar
Significant temperature drop on line sets indicates restriction. Easy to test. I guess A-coil has something inside.
Old 09-16-2011, 10:11 AM   #44
Rewards Points: 640
well calling them back out and telling them they didn't fix it... see what happens....
Old 09-16-2011, 03:43 PM   #45
An old Tradesmen
Is there a liquid line filter drier inside the outdoor unit, or one on the line just outside the outdoor unit, or one at the air handler/evap coil?
how to build a single phase induction motor sashman Electrical 3 03-31-2011 08:18 AM
Balcony Drain Freeze sueann Roofing/Siding 2 10-28-2010 09:58 PM
Timecutter 16:42z trouble starting and now stopped starting jackdoldno7 Landscaping & Lawn Care 0 09-10-2010 12:43 PM
Freeze protection in utility room? akguy HVAC 1 11-20-2009 06:30 AM
Heil Gas Furnace has trouble starting sometimes dmanmtl HVAC 3 01-23-2009 06:36 PM
