AC Starting To Freeze? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-30-2011, 08:09 PM   #16
Rewards Points: 640
Originally Posted by beenthere View Post
Does your system have a TXV?
Did the tech only look at pressures, or did he also check SH and SC.
Honestly, I don't know, he had it running for a while with gauges on it, looked around checked temps checked all the caps... might have to call someone else out to see, anything else I should explicitly say to check besides what you just said?
BlueBSH is offline   Reply With Quote
Old 08-30-2011, 10:39 PM   #17
Ron Paul 2012
In my experience, with evap's icing up it was because of clog in the TXV or poor air circulation. I would call the tech back and tell him you paid him to find out the issue and refuse to pay until he can let you know what's going on.
HandymanCA is offline   Reply With Quote
Old 08-31-2011, 04:40 AM   #18
An old Tradesmen
Rewards Points: 7,378
Super heat and sub cool. Temp delta across the evap coil, along with amp draw of the indoor blower motor.
Old 08-31-2011, 01:20 PM   #19
Rewards Points: 640
thanks! have them coming back out today if they have time or friday... I know this is a DIY forum, but this got over my head interms of abilities and tools fast since the common problems I already checked
Old 08-31-2011, 04:44 PM   #20
An old Tradesmen
Understandable.
Old 09-02-2011, 12:08 PM   #21
Rewards Points: 640
well differnet tech came out today, said right away the orface is restricted, which makes sense since it was freezing right after it... but then he got confused why the coil has a differnet size one then what it says was put on, then has a third size that doesn't match listed on another label... so they are going to look up the install records since they did the install back in 2004.... see what happened... then schedule a return to evac the r-22 back to the compressor unit and replace it... definatly dont have the tools to do that myself
Old 09-02-2011, 04:21 PM   #22
An old Tradesmen
The orifice is suppose to match the condenser. The condenser of a matching system will say what size orifice to use.
Old 09-06-2011, 02:16 PM   #23
Rewards Points: 640
yeah, they are saying they don't match now.... this system has been here for a number of years now and it hasn't matched that entire time.... and just now starts to freeze up...
any idea on how long it takes to purge a coil and recover the R22 on a 4 ton system with 25 ft of line to the condensor? they haven't scheduled a time yet but all they would tell me is "it could take hours"
Old 09-06-2011, 02:35 PM   #24
JJboy's Avatar
Pump Down - 15 minutes
Replace and Install Orifice - 1 hour
Replace filter drier - 45 minutes
Leak test - 30 minutes
Vacuum - +/- 2 hours
Check SH and SC - 20 minutes to stabilize the system + 30 minutes
Drink water, smoke, piss - 20 minutes
So "it could take hours"
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 09-06-2011, 05:59 PM   #25
An old Tradesmen
If they have good recovery machines, less then 30 minutes. I recover by liquid first, and then vapor, so it doesn't take me real long.
Old 09-06-2011, 06:15 PM   #26
I'm Your Huckleberry
Rewards Points: 2,270
I doubt they have good recovery machines, BT. As it is they installed the wrong piston and didn't nitro flush the line set and pull a good vacuum as the orifice is now restricted. Those are serious signs of inadequate or uncaring technicians as orifices don't just clog up on their own out of the blue, there has to be trash in that line. Not good.
Hopefully this new tech (assuming he's new) from the same company can turn things around for them as apparently they need turning around, IMO.
JJboy, it takes you 15 minutes to pump down a system? Do you fall asleep/take a short nap/ forget what you're doing/where or who you are/suffer from amnesia during the process or what?
I would say no more than 2 minutes. Why 15?
Doc Holliday is offline   Reply With Quote
Old 09-06-2011, 06:40 PM   #27
JJboy's Avatar
LOL I spent 15 minutes to write this message. 15 my minimal
Old 09-09-2011, 07:29 AM   #28
Rewards Points: 640
well after snooping around the system I found a sticker that says the AC and coil where installed in 2003, the furnace was installed in 2007, so the AC unit is 8 yrs old and apparently never had a problem..... but then the previous owners apparently never had it checked out yearly or ever at that... only when I have a tech out to start doing yearly service does the unit freeze up.... go figure.....
all they did was replace a bad cap and put in more R22, worked great... for about 2 weeks then started to notice airflow problems, then all the sudden one day felt like it wasnt getting cool in the house and boom its iced over after the orface......
apparently its a different set of techs coming out to do this work *crosses fingers* this coming thursday.... and going to give the whole system a once over including the furnace just to be sure......
this is the biggest heating company in the area that services this, definatly has a lot of gadgets and high tech ones at that... but are they top quality?... no idea
they service our commercial units at our building at work, and we um tend to call them the "screw up crew"... everytime they come it seems like we have a new problem... once they even caused a glycol line to burst and destroyed 2 offices......
because of them ive contemplated moving to a different brand system, its lenox right now... and they are the only auth dealers in the area for it... i know others can work on them, but would rather have the dealer service their equip..
Old 09-09-2011, 08:40 AM   #29
Rewards Points: 640
well, this just got a little more concerning...... AC hasn't ran for what a week now? went downstairs and there is a puddle of water around the furnace it looks like it came out the blower compartment.... now I doubt it takes a week for ice to thaw when the ambient temp is 70+..... what in the world could of caused this....
Old 09-09-2011, 01:09 PM   #30
JJboy's Avatar
Evap coil is freezing due to low refrigerant or poor air flow. You need to check for leakage of refrigerant.
The drain line should be clogged.
how to build a single phase induction motor sashman Electrical 3 03-31-2011 07:18 AM
Balcony Drain Freeze sueann Roofing/Siding 2 10-28-2010 08:58 PM
Timecutter 16:42z trouble starting and now stopped starting jackdoldno7 Landscaping & Lawn Care 0 09-10-2010 11:43 AM
Freeze protection in utility room? akguy HVAC 1 11-20-2009 05:30 AM
Heil Gas Furnace has trouble starting sometimes dmanmtl HVAC 3 01-23-2009 05:36 PM
