AC Running Continuously - HVAC - DIY Chatroom Home Improvement Forum
Old 08-28-2011, 03:18 PM   #1
Hi...I have a strange problem, MY AC unit is running continuously no matter what i do with the Thermostat. Even when the thermostat was set to off the AC unit was running. Infact I took the thermostat out ( disconnecting all the wires) and still the AC was running...Any ideas what could be going on ( Its York Diamond 90 unit).
Thanks in advance
Alind Saxena is offline   Reply With Quote
Old 08-28-2011, 03:54 PM   #2
Rewards Points: 6,652
Stuck contactor out in the condensor unit possibly. What happens if you shut the power down on the furnace inside the house?
Old 08-28-2011, 03:56 PM   #3
Thank you for your response. When i turn the power switch ( inside) next to the unit off then everything shuts down.
Old 08-28-2011, 04:50 PM   #4
Then it is a issue with your indoor unit (ie furnace) circuit board if it has one. Post manufacturer & model#, and those that can go further with this will be along.
Old 08-28-2011, 10:09 PM   #5
Hmmm...Why would you say that...I think the power to contactor will be going from the main switch inside so even if it is stuck it will power off when the main switch is closed...
The Unit is Diamond 90 from York.
Old 08-28-2011, 10:16 PM   #6
Did the air conditioner stop running, when you shut off the furnace?
Old 08-28-2011, 10:17 PM   #7
AKA HVACTECHFW
Rewards Points: 1,208
remove thermostat Y wire and see if outdoor unit shuts off. If it does it is stat. If it does not then it is either in the wiring or the furnace bard.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 08-28-2011, 10:37 PM   #8
I have disconnected the Thermostat all together but the moment i turn on the power switch next to furnace the AC kicks on. Also..only the AC unit (compressor outside) comes on..not the blower.
Old 08-28-2011, 10:39 PM   #9
yes the AC compressor stops running if i turn the power switch to the furnace off.
Old 08-28-2011, 10:40 PM   #10
AKA HVACTECHFW
this indicates you are sending 24V to the contactor... either your wire is shorted to power or a bad control, most likely not the furnace control board as it is just a dummy terminal.
You need to find where the 24V signal to the contactor is coming from............(where it is picking up 24V....the wiring or the board)
IT IS WHAT IT IS
Old 08-29-2011, 12:45 AM   #11
Check the wires going from the contactor to the circuit board. It should be connected to C and Y Terminal.
Mr.HVAC is offline   Reply With Quote
Blower continuously running AboveTheBULL HVAC 8 08-30-2012 06:02 AM
Running cat5 wire over ventilation / heating ducting ajtool General DIY Discussions 7 06-11-2010 01:45 PM
constant running water sound gmk2008 Plumbing 9 11-11-2008 09:22 PM
Blower operates continuously ryan0320 HVAC 3 12-03-2007 11:39 PM
taco 700 constantly running.... drizzyboy HVAC 3 11-27-2007 08:03 AM
