Old 07-20-2012, 11:45 AM   #1
ac running but not cooling my house
My ac stopped cooling my house 2 days ago. I t is blowing low pressure cool air but it is not cold air. Do you think I need freon or something else is wrong? The air is set at 70 but it is reading 80 it is very hot in my house. I need some help.
opal16 is offline   Reply With Quote
Old 07-20-2012, 12:02 PM   #2
Willing to listen
First check to make sure you have a clean filter in the indoor unit. Let us know....
Done That is offline   Reply With Quote
Old 07-20-2012, 12:32 PM   #3
I changed the filter in the furnace if that is the right one.
Old 07-20-2012, 01:17 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Is outside unit running????
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 07-20-2012, 01:26 PM   #5
Check to make sure all the air is making it into your home. A line could have come off. I just replaced the blower motor on one of my units and used coil cleaner to finish off the job. Make sure your coils are clean. My 5 ton unit on the roof has never been cleaned. I didn't think it could be dirty being that it is on the roof. Boy was I wrong! Do not use the coil cleaner from HD or Lowes. They don't work like the commercial stuff.
frazee1 is offline   Reply With Quote
Old 07-20-2012, 01:43 PM   #6
I checked outside and only the fan is runming does that mean the compressor is bad?
Old 07-20-2012, 01:47 PM   #7
plummen's Avatar
Could be many reasons its not running,shut the ac off and let it cool down for a few hrs is the first thing a diy can do.
Could be electrical connection/capacitor good be bad/bad contactor/could be really low on freon and compressor is thermally protecting itself/bad compressor..........
Let if cool down then try turning it back on first
Old 07-20-2012, 01:51 PM   #8
Willing to listen
Not necessarily. Could be a capacitor, failed wiring connection to the compressor, compressor internal protector tripping from low refrigerant charge, etc, etc. Might be time to call a good tech out and get it fixed.
running but still not cooling off wd45gto HVAC 6 08-03-2011 10:10 PM
Cooling a whole house on a wall AC unit RedHelix HVAC 15 07-20-2011 11:53 AM
running outdoor cable from house to detached shed above ground amakarevic Electrical 2 11-19-2010 03:16 PM
running electric from house Tradesman14 Electrical 3 01-14-2010 12:16 PM
Second Story house cooling question. darktiger HVAC 12 08-08-2009 10:30 PM
