#1 |
AC pump won't quit runnuning
I have a Carrier Weather Maker 9200. The cold air return is under the unit . There is a pump in the cold air return area that pumps the water collected outside of the house. We live in Southern California so it's not extremely humid. For the last couple of days the pump hasn't quit running, even when the unit is off. About two weeks ago I extended the drain hose quite a way from the house because it was draining right next to the house and we have a possible mold problem so I wanted to get as much moiusture away from the house as possible. Help
#2 | |
AC pump won't quit runnuningQuote:
If you used soft tubing its likely that the extra static pressure would overcome the pump and the water wouldn't go anywhere. |
| Display Modes | |
| MasterCraft shallow well pump not happy | rtoni | Plumbing | 7 | 06-06-2011 12:41 PM |
| Sump pump operation | MikeKy55 | Plumbing | 16 | 05-11-2011 05:35 PM |
| Well Pump Problems | dannyjoe | Plumbing | 6 | 10-01-2009 07:10 PM |
| Modification to an existing pump switch | DRBLKJK | Electrical | 10 | 08-23-2009 04:06 PM |
| Sump Pump Questions | henlij | Plumbing | 19 | 08-12-2009 08:50 PM |
