Old 06-21-2009, 12:04 AM   #1
ac problems
i have a goodman central ac unit 2.5 tons, it is haveing a problems, it is not able to cool down my house in the heat of the day. the freeon is okay, but it is running low presssuer on the high side 3/8 line . verry high on the low side 3/4 line yet not getting cold or even sweeting on the low side.
egcollom is offline   Reply With Quote
Old 06-21-2009, 12:11 AM   #2
hvaclover's Avatar
ac problems
how'bout some periods so we can make sense of your post.
What do you interpret as the lo and hi side? Would be helpful to know so we can direct you.
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 06-21-2009, 12:24 AM   #3
ac problems
okay on my unit. on the low pressure side, the large line the cold line it is not geting cold and the pressure is running high. on my high pressure side the 3/8 line it is warm but running a very low pressure.
Old 06-21-2009, 12:28 AM   #4
hvaclover's Avatar
ac problems
and what were the pressures? How did you measure them? Gotta know so i can determine how accurate they are.
Old 06-21-2009, 12:37 AM   #5
ac problems
okay, i dont have my gauges in front of me but this is what i have wrote down in my log book. at 9 pm on the low side it read 98 lbs on the high side it was 210 lbs.
room temp was 80.5 air temp coming out of air duct was 69.8
Old 06-21-2009, 12:43 AM   #6
hvaclover's Avatar
ac problems
Gee, your right...it's broke!
Try a little manners friend. I don't need the 'tude when I'm giving free advice this time of the morning. I asked those question to try to help you but you can get nasty with the trolls who frequent here.
Old 06-21-2009, 12:48 AM   #7
ac problems
sorry!!!! I have fixed holes in the duct work, and lose wires on the unit, it is starting to get to me im new at this stuff please give me some help
Old 06-21-2009, 12:50 AM   #8
hvaclover's Avatar
ac problems
my ac is working. Good night.
Old 06-21-2009, 12:51 AM   #9
ac problems
do you have any thought of what else i need to do
Old 06-21-2009, 07:56 AM   #10
An old Tradesmen
ac problems
Is it a heat pump.
Old 06-21-2009, 08:25 AM   #11
ac problems
no it is not a heat pump, standard two pcs unit gas heat, r22 freeon it is a goodman
Old 06-21-2009, 08:28 AM   #12
An old Tradesmen
ac problems
What was the outside temp when you took these readings.
Old 06-21-2009, 08:34 AM   #13
ac problems
about 100' outside 85 inside
Old 06-21-2009, 08:42 AM   #14
An old Tradesmen
ac problems
210 PSIG head pressure is a saturation temp below ouotdoor ambient.
A restricting liquid line filter drier installed inside the condenser can cause that.
Or a low charge.
You should take all readings again.
And record indoor drybuld temp and wet bulb temp.
Out door drybulb temp.
Head pressure, and liquid line temp.
Vapor pressure and vapor line temp.
Entering and leaving wetbulb and dry bulb temps at the coil(not at registers).
Old 06-21-2009, 08:46 AM   #15
ac problems
okay, im in central time zone . im going to look at it today it is about 45 min away i will post again win in get more info.
thank you.
glenn
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 02:51 PM
How to diagnose problems with wall kahlan General Discussion 5 10-22-2008 10:18 AM
Elec short causing A/C problems or A/C problems causing elec problems? Marlon Electrical 2 06-25-2008 03:04 PM
Are you having ice problems? Grumpy Roofing 27 02-17-2008 04:51 PM
