AC Power Stops At Fuse Box - HVAC - DIY Chatroom Home Improvement Forum
Old 06-16-2009, 09:58 AM   #1
AC power stops at fuse box
Hello All,
My home was built in 1989. I am sure the air conditioner is original to it. This summer the outside unit (fan not spinning) stop working. I tested the wiring inside the house and got a positive read. I tested the wire outside and the portion that leads from the inside of the house has a reading for electrical current, but past the fuse box that portion is not receiving power. I tried replacing the fuse since that seems to be the problem, but that did not help. Any other suggestions I can try?
Campbeco is offline   Reply With Quote
Old 06-16-2009, 12:01 PM   #2
fuses
Were the fuses new or laying around in the box???????????
Possible corrosion at the knife blades, or pull out.
I'm stumped also.
SULTINI is offline   Reply With Quote
Old 06-16-2009, 06:44 PM   #3
biggles's Avatar
with the fuses in if you read the top 208V and it has power then the lower portion of the fuse going into the condenser doesn't the fuses are blown
Tags
ac unit , air conditioner , air conditioning , condenser , fuse
Wring for Lincoln Power Mig Welder vstoyko Electrical 17 01-15-2009 07:15 PM
Fuse OK! No power to outlets... henry199 Electrical 9 12-25-2008 09:10 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
100 Amp Fuse - issue - HELP! Leenders Electrical 9 06-02-2008 05:06 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
