-   -   AC power stops at fuse box (http://www.diychatroom.com/f17/ac-power-stops-fuse-box-46765/)
Campbeco 06-16-2009 09:58 AM
Hello All,
My home was built in 1989. I am sure the air conditioner is original to it. This summer the outside unit (fan not spinning) stop working. I tested the wiring inside the house and got a positive read. I tested the wire outside and the portion that leads from the inside of the house has a reading for electrical current, but past the fuse box that portion is not receiving power. I tried replacing the fuse since that seems to be the problem, but that did not help. Any other suggestions I can try?
SULTINI 06-16-2009 12:01 PM
fuses
Were the fuses new or laying around in the box???????????
Possible corrosion at the knife blades, or pull out.
I'm stumped also.
biggles 06-16-2009 06:44 PM
with the fuses in if you read the top 208V and it has power then the lower portion of the fuse going into the condenser doesn't the fuses are blown
