Old 06-02-2010, 07:06 PM   #1
AC Not working
Hi,
I have carrier 9200 weather maker, which is 9 years old but every year it has problem in Spring and Winter. The latest code is "LED Light ON" meaning "on 24VAC power" (don't know what that means). Please help me if you know what it is and save me from exponential charges (which I keep paying every vist).
Vizag
Vizag17 is offline   Reply With Quote
Old 06-02-2010, 07:18 PM   #2
AC Not working
When you turn the fan to on at the t-stat does it come on?
try the A/C, does the indoor blower come on?
In A/C mode does your compressor or fan try to come on?
Also check to see if the cond. pump is working"if you have to pour some water in it to see if it runs"
mikethe ductman is offline   Reply With Quote
Tags
24vac power, carrier, weather maker9200
Circuit stopped working, breaker did not trip nr5667 Electrical 7 07-08-2012 04:31 AM
No heat but working AC xevier69 HVAC 4 01-30-2009 06:31 PM
side by side light swithes not working katkell2645 Electrical 2 10-17-2008 08:22 PM
Inside Fan not working BenH HVAC 20 07-08-2008 07:10 AM
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 02:47 PM
