AC Not Working - HVAC - DIY Chatroom Home Improvement Forum
Old 07-20-2013, 07:03 PM   #1
Rewards Points: 121
AC not working
My Central air stopped working today, the thermostat is calling for it, the fan on the furnace runs but the condenser fails to start,
what should i be looking for and what to test... thanks...
rick31797 is offline   Reply With Quote
Old 07-20-2013, 07:13 PM   #2
An old Tradesmen
Rewards Points: 7,816
Tripped breaker.
Tripped high pressure switch.
Bad dual run capacitor.
Old 07-20-2013, 08:09 PM   #3
Rewards Points: 582
look to see if someone cut 24 volt control wire with weed wacker???? 8-10 of there jobs last week....ben sr
Old 07-20-2013, 08:37 PM   #4
raylo32's Avatar
Rewards Points: 1,294
Yikes, never heard of that but I guess it could happen. Pretty bad timing with the heat wave! Rick, how old is your system? If it has some miles on it and if the breaker isn't tripped there's a good chance it is just the dual run capacitor that starts the compressor and outside fan. Have a look and see if it is bulging.
Live long and prosper.
raylo32 is online now   Reply With Quote
Old 07-21-2013, 01:57 PM   #5
Rewards Points: 121
Thanks for the replies, feel a bit dumb, it was just a fuse, so all is good now..
Old 07-21-2013, 02:53 PM   #6
FClef's Avatar
Rewards Points: 160
Never feel dumb about asking questions, it is the way we learn things.
Glad it was just a fuse. Hopefully it will not go out again, if it does we can help you figure it out.
FClef is offline   Reply With Quote
Old 07-21-2013, 04:09 PM   #7
Rewards Points: 121
Thanks everybody...i have had my AC for 17 yrs with no issues, not even a blown fuse, when it went, i guess i was thinking because of its age, it cant be as simple as a fuse, usually anything that breaks around here is not that easy to fix..lol
Old 07-21-2013, 04:36 PM   #8
raylo32's Avatar
Rick, glad you got it working. Are you talking about the fuse on the air handler/furnace control board? Just curious...
Old 07-21-2013, 04:43 PM   #9
Rewards Points: 121
I am talking about the main fuse in the electrical panel, there are two 20 amp fuses and one was blown
Old 07-21-2013, 05:07 PM   #10
raylo32's Avatar
Oh, I haven't seen an electric panel with fuses in a very long time.
gas dryer not working bcw0801 Appliances 4 05-03-2011 05:11 PM
Water Filled Gas Furance Not working szym0n HVAC 1 02-21-2011 04:46 AM
Receptacle stopped working lovetobuild Electrical 3 02-11-2011 10:05 AM
side by side light swithes not working katkell2645 Electrical 2 10-17-2008 07:22 PM
Two switch in one box: only one working jdtsmith Electrical 12 09-29-2008 01:32 PM
