Ac Not Cooling, Suction Line Freezing, Suction Pressure In "Retard" - HVAC - DIY Chatroom Home Improvement Forum
Old 05-25-2011, 05:46 PM   #1
GetYourShineBox's Avatar
ac not cooling, suction line freezing, suction pressure in "Retard"
i installed a few condensers over the past 2 weeks at the complex i work at. one of them when i installed it , it ran fine , 75 psi on the suction side. exhausting heat, blowing cold air, no problem. today i get a call that the system is not cooling. i go over, i run it, compressor kicks on, so i check to see if the blower is seized up, blower running fine. hook my gauges up and suction side goes right into "retard". it was the end of the day so i just wanted to check real quick before coming back tomorrow. i go to pull my gauges off and refrigerant is just shooting out like there is just immense pressure. i had to cup my sleeve in order to get my line off. any thoughts on whats going on here? is it over charged somehow? ran fine at install. appreciate it.
GetYourShineBox is offline   Reply With Quote
Old 05-25-2011, 06:11 PM   #2
What was your head pressure? Any chance you had it on the wrong port?
Old 05-25-2011, 06:13 PM   #3
didnt take a high side. bad habit i guess. no it was on suction.
Old 05-25-2011, 06:26 PM   #4
Post up what you find tomorrow so we all can learn something new. The only times my suction hit retard was when it was hot as blazes out and the compressor didn't run and when I put it on the wrong port.
Old 05-25-2011, 07:21 PM   #5
HVAC Tech
Ducthunter's Avatar
Or you got a major restriction somewhere, causing it to pull your low side into a vacuum. This a txv or piston?
Ducthunter is offline   Reply With Quote
Old 05-26-2011, 12:01 AM   #6
AKA HVACTECHFW
Rewards Points: 1,208
cant properly install/charge a unit without high side gauge!
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 05-26-2011, 07:48 PM   #7
mark this one under the retard section. it was a long day. had it on the wrong side after all. sorry.
Old 05-26-2011, 09:01 PM   #8
Pretty sure that's why they put retard on there instead of caution , to make us feel bad for messing up
Making nice tight bends in 1-1/8" Suction Line hennyh HVAC 8 10-28-2009 10:13 AM
ac suction line placement? nimbenja HVAC 8 10-28-2009 05:43 AM
suction line insulation? Lookin HVAC 8 06-06-2008 04:33 AM
High pressure in water line atlfiveo Plumbing 5 02-06-2007 09:04 PM
Gas Line pressure testing standard(s) rolson6432 Plumbing 1 09-09-2006 02:33 PM
