AC Not Cooling To Correct Temperature - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-30-2014, 09:40 PM   #16
I'm Your Huckleberry
Rewards Points: 2,270
original topic: are all components of the system turning on and running, inside blower and outside condenser?
Is there a float switch on the drain lines possibly cutting out condenser due to a backed up drain?
If all system is on yet not cooling most likely a refrigerant issue..
Thanks.
Doc Holliday is offline   Reply With Quote
hvac, balancing temperature, correct height to measure from floor.... carco.industrie HVAC 1 01-17-2013 06:31 PM
Condensation in middle of window byon49 Windows and Doors 2 10-30-2012 01:26 PM
InfThermometers and Accurate Room Temperature leftygroove HVAC 5 08-23-2012 09:34 PM
Replace just the Cooling Unit for Condo HVAC System acj74 HVAC 19 07-22-2012 03:03 PM
Installation of Honeywell Thermostat - cooling function KDW Electrical 0 10-04-2009 10:56 AM
