AC Not Cooling - HVAC - DIY Chatroom Home Improvement Forum
Old 10-23-2008, 09:49 PM   #1
AC Not cooling
I just changed my air filter on my AC unit and all of a sudden its not cooling anymore. It was cooling fine b4 I changed it and now it wont go any coolder than 74. Any ideas what could be wrong here? The unit is only 5 yrs old.
cougarican is offline   Reply With Quote
Old 10-24-2008, 02:01 PM   #2
Supplier
Unless you switch off something or had a loose wire or something like that in the process of changing the filter the unit won't stop cooling just because you changed the filter. Check the area that you work on and see if you mess up something in the process first. Hope this helps.
gsistore
gsistore is offline   Reply With Quote
Old 10-24-2008, 02:16 PM   #3
If it's pulling down to 74 do you mean that the a/c is running but now won't keep the usual temp you set it at.
Only thing comes to mind is the blower door switch might not be closed aLL THE WAY .
Was the temp higher then normal when you changed the filter?
hvaclover is offline   Reply With Quote
Fridge not cooling - evap fan? oppiecat Appliances 4 07-02-2013 04:19 PM
Help! Just changed my Fan Controler (ICM 275) now system "false starts" when cooling redmachodevil HVAC 4 01-26-2011 03:21 AM
Geothermal cooling loop help stuartm HVAC 2 09-29-2008 10:18 PM
Heat Pump/AC not cooling, new home eshipler HVAC 7 07-25-2007 08:52 PM
Central AC not cooling 2nd Floor ejpdlg HVAC 6 07-17-2007 03:10 PM
