Ac Not Cold - HVAC - DIY Chatroom Home Improvement Forum
Old 06-24-2012, 09:10 PM   #1
ac not cold
Ok so if itís not one thing itís another. outside 96 degrees inside 86
My air is flowing and it is not cold
I go outside and the condenser is running and it will turn off not running very long. But the house air is not very cold and is not cooling the house down. The pipes that go to and from the ac unit are not cold or hot just what i would expect it to be from the normal air around it.
Ideas?
Not used much at all only 7 years old.
robkiller is offline   Reply With Quote
Old 06-24-2012, 09:15 PM   #2
JJboy's Avatar
It's time to hook up the gauges and check the proper refrigerant charge, check the filter, check if the condenser coil is clean....etc
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 06-24-2012, 09:18 PM   #3
Ya i may need to have someone do that. I just dont understand why the fan would turn off when its needing to be on even with low coolant.
Old 06-24-2012, 09:41 PM   #4
AKA HVACTECHFW
Rewards Points: 1,208
a low pressure switch would be turning the condenser off to protect the compressor.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 06-24-2012, 10:30 PM   #5
That seems to be what its doing. I assume the fan will turn off along with the compreasure?
Old 06-24-2012, 10:41 PM   #6
JJboy's Avatar
Yes.....Turn AC OFF
Old 06-24-2012, 10:54 PM   #7
i dont have anything to check and recharge the unit. Would you say more cost affective to get that stuff and do it or call someone?
Old 06-24-2012, 11:05 PM   #8
JJboy's Avatar
This procedure is not simple as replace a capacitor .....
Do I need this cold air return, pictures shown steffen707 HVAC 8 01-18-2012 02:39 PM
Hot Water Turning Cold - Could it be the washer/dryer? kissiffer4 Plumbing 3 01-28-2010 04:47 PM
Cold air return questions ekulrenlig HVAC 19 10-09-2009 01:44 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 08:05 AM
