AC Not Blowing Cool Air. - HVAC - DIY Chatroom Home Improvement Forum
Old 08-10-2012, 08:12 PM   #1
AC not blowing cool air.
My AC stopped blowing cool air a week ago and we had someone come out and look at it and he said it had frozen and was low on freeon. He let it thaw for about 2 hrs and put in the freeon. It worked until now, its doing the same thing and i also have water on the floor. What could it be?
Cofy is offline   Reply With Quote
Old 08-10-2012, 08:20 PM   #2
PE Mechanical Engineer
Thunder Chicken's Avatar
Rewards Points: 834
All the Freon that he put in leaked out again. When the pressurized refrigerant expands through the leak its temperature drops. It probably condensed a lot of moisture in the air while it was leaking.
Have to fix the leak before recharging will work.
Thunder Chicken is offline   Reply With Quote
Old 08-10-2012, 08:24 PM   #3
refrigerant leaked out agin. coil froze thicker missing the drain pan as it melts.
turnermech is offline   Reply With Quote
Blowing hot air - Set on Cool shunail HVAC 15 06-19-2012 07:29 AM
Cool air blowing, house not cooling helping friend HVAC 3 07-23-2011 07:25 AM
Air conditioner blowing cool but not cooling house roguefox64 HVAC 3 07-03-2011 11:21 PM
Outside Trane - heating and air unit- blowing cool air inside home but not getting below 85 degrees Leatha HVAC 1 07-25-2010 07:32 PM
dayton furnace blowing cool air luckysc47 HVAC 2 12-05-2009 12:04 PM
