Old 05-17-2011, 01:38 PM   #1
AC not blowing cold air - was told have leak in coil- Cost?
AC was not blowing out cold air and I had a HVVC tec come and look at it. He tested for leaks and said there was a leak in the mail coil (big coil in upper par of furnace). It is very low on refrigerant so he said coil needs replaced. Estimate is around $1000 without cost of refidgent (freon). Says with the new coils they are bigger and do not fit in the old furnace so the top part of furnace needs a new box. Does the estimate and what he says sound right?
Thanks,
H.O.P. is offline   Reply With Quote
Old 05-17-2011, 03:00 PM   #2
I'm Your Huckleberry
By box you mean plenum, the plenum box is where air is distributed throughout the ducts and yes, they need to fit the coil and newer coils are bigger.
If just for the coil, 1k is an absolute steal. If that price includes the new plenum then you belong in prison as that is highway robbery.
Doc Holliday is offline   Reply With Quote
Old 05-17-2011, 04:34 PM   #3
An old Tradesmen
Very cheap price.
Old 05-17-2011, 08:47 PM   #4
yeah, very cheap, i was quoted $1500 for a similar repair last year including resizing the plenum to fit the large coil.
NitroNate is offline   Reply With Quote
cold air blowing from vent annyellin HVAC 0 12-19-2010 06:10 PM
HEIL/ICP gas/electric self-contained unit -- blowing cold air, won't shut off AboveTheBULL HVAC 3 06-28-2010 07:23 AM
Does a water to air coil cost more than a regular coil? abefroman HVAC 15 09-22-2009 06:19 PM
How much should a new water to air coil and blower cost, installed? abefroman HVAC 2 09-02-2009 07:17 PM
