Ac Malfunction - HVAC - DIY Chatroom Home Improvement Forum
Old 07-02-2011, 05:24 PM   #1
ac malfunction
My outdoor central air unit is not working the fan in the unit is spinning but there is no air coming thru the vents if there is anyone that can be of any asistance please reply back its 113 degrees in arizona and my babies are hot
joybanks is offline   Reply With Quote
Old 07-02-2011, 07:21 PM   #2
An old Tradesmen
Rewards Points: 6,060
Check air filter. Check in indoor blower is running.
Do you have and know how tom use a multimeter.
Old 07-02-2011, 09:27 PM   #3
Rewards Points: 184
Could be low on compression and/or freeon, you should have it checked out if you don't have a guage.
abefroman is offline   Reply With Quote
Old 07-02-2011, 10:33 PM   #4
Is the coil iced up inside the house?
Is the fan on the inside working?
Artco is offline   Reply With Quote
Old 07-03-2011, 06:10 AM   #5
Rewards Points: 184
Also when is the last time you cleaned the coils?
oven door seal replacement, self-cleaning function malfunction YerDugliness Appliances 10 02-28-2011 10:22 PM
Home theatre rear speaker malfunction Bazbee Electrical 1 02-11-2011 11:14 PM
Apartment Heating Malfunction Honeywell Pump RCH HVAC 0 11-24-2010 06:06 AM
thermostat goes to malfunction mode when it reaches set temperature Bobalu HVAC 0 08-23-2010 08:35 PM
Ceiling Wiring Malfunction? wikkie650 Electrical 5 07-05-2010 10:24 PM
