AC Line Set Through Crawl, Any Helpful Hints? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-24-2013, 01:40 PM   #1
AC line set through crawl, any helpful hints?
Hi all,
I'll be installing an ac line set through a pretty bad crawlspace. No other options because my condenser is in the center of the home, 1st floor. The crawlspace is minimum code clearance, so it's difficult to maneuver. The distance from end to end will be about 35', shorter if I don't have to make too many wide turns.
I'm concerned about having any dips in the lines going under a beam or some other obstruction like DWV plumbing. What are the acceptable vertical drops and rises in elevation of the piping run? Or, should I be concerned at all about this? I realize I can't make sharp turns without risking a kink in the copper.
Any helpful hints?
Thanks.
RM575 is offline   Reply With Quote
Old 09-24-2013, 02:00 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 380
You can dip up and down all U want. As long as U are under 50 feet of line nothing else needs 2 B done. Use copper or nylon covered perforated strapping NOT steel or galvanized to hang it. Steel/galvanized will react with the copper liquid line.
The Following User Says Thank You to yuri For This Useful Post:
ben's plumbing (09-24-2013)
Old 09-24-2013, 02:24 PM   #3
Thanks. I thought I might be fretting over nothing. Got it on the non-galvanic hangers.
Old 09-24-2013, 05:17 PM   #4
Rewards Points: 616
no worries if its r-410 for sure... lots of velocity there.... As Yuri says dip all you want as long as the line size is correct......
carmon is offline   Reply With Quote
Condensate Drain Line Mystery flhvac HVAC 9 06-01-2013 11:08 PM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 02:56 PM
sewer line Master Brian Plumbing 3 05-25-2009 12:53 AM
