Old 06-05-2010, 08:21 PM   #1
AC leaking condensation leaking into furnace
My 2nd furnace / AC unit is leaking into the furnace. I cleaned the drain hole to make sure it wasn't blocked turned it on and it worked fine for about 6 hours then started leaking again. i noticed the coil is frozen solid. Its icing up the drain hole? I checked the compressor outside and i don't see any icing anywhere else. It a carrier SX58 vintage 92.
Any idea as to why???
jrf0022 is offline   Reply With Quote
Old 06-05-2010, 08:52 PM   #2
Frozen coil is usually due to dirty air filter, dirty coil or low freon.
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Furnace leaking water Red Squirrel HVAC 5 09-22-2009 04:13 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
York Furnace Leaking.. Please help sidoe HVAC 4 10-08-2007 05:55 PM
