-   -   AC leaking condensation leaking into furnace (http://www.diychatroom.com/f17/ac-leaking-condensation-leaking-into-furnace-72931/)
jrf0022 06-05-2010 07:21 PM
My 2nd furnace / AC unit is leaking into the furnace. I cleaned the drain hole to make sure it wasn't blocked turned it on and it worked fine for about 6 hours then started leaking again. i noticed the coil is frozen solid. Its icing up the drain hole? I checked the compressor outside and i don't see any icing anywhere else. It a carrier SX58 vintage 92.
Any idea as to why???
jogr 06-05-2010 07:52 PM
Frozen coil is usually due to dirty air filter, dirty coil or low freon.
