Old 09-15-2011, 10:58 PM   #1
Ac leaking
Condensation not flowing into drip pan leaking onto insulation and rugs drainage not clogged
MLM09 is offline   Reply With Quote
Old 09-15-2011, 11:03 PM   #2
JJboy's Avatar
Ac leaking
Where does it go then?
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 09-16-2011, 08:31 AM   #3
Ac leaking
It is leaking onto my carpeting and on the insulation my unit is in the upstairs of my town home
Old 09-16-2011, 08:47 AM   #4
JJboy's Avatar
Ac leaking
I think you have an air leak. The cold air is getting condensated.
Old 09-16-2011, 05:06 PM   #5
Ac leaking
My brother blew out the lines still leaking a little itnis a drip drip then a little stream
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 11:21 AM
AC leaking condensation leaking into furnace jrf0022 HVAC 1 06-05-2010 08:52 PM
Leaking Box Window Omeleto Building & Construction 9 02-19-2010 05:40 PM
leaking roof couchguy Roofing 1 02-13-2010 05:43 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 09:53 PM
