ac keeps tripping the breaker
Ac unit keeps tripping my breaker. Ohmed my compressor reading were fine capacitor checked out fine as well. Whats my problem?
and the condenser fan 208V wires? check that condenser motor for ground and continuity on the windings.on the compressor you went to ground from each terminal and had infinity:wink: dead short between windings is normal(or ohm values).what shape is the contactor in burnt arc'd.check the 208V out to the disconnect reading voltage,and the disconnect to compressor contactor without the unit calling from the stat..
:thumbsup::thumbsup:
| All times are GMT -4. The time now is 12:33 AM. |
