Ac Keeps Blowing The 5 Amp Fuse - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-06-2012, 10:22 PM   #16
It is the blower motor. check AMP while it is running....it probably getting higher and higher...
clocert is offline   Reply With Quote
Old 05-06-2012, 10:25 PM   #17
Rewards Points: 616
I do not think the blower motor is the problem....
carmon is offline   Reply With Quote
Old 05-06-2012, 10:31 PM   #18
I'm Your Huckleberry
Rewards Points: 2,270
Thanks.
Doc Holliday is offline   Reply With Quote
Old 05-07-2012, 04:19 AM   #19
An old Tradesmen
Rewards Points: 8,168
The 5 amp fuse is on the low voltage side, so its not the blower motor causing it to blow.
Is this a heat pump, or straight A/C.
Old 05-07-2012, 05:11 PM   #20
fuse blowing
this is a straight ac
dlastra is offline   Reply With Quote
Old 05-07-2012, 05:14 PM   #21
An old Tradesmen
Good chance the contactor coil is going bad.
Old 05-07-2012, 05:22 PM   #22
Yup yup. To further this notion, with the breaker off to the inside furnace as well as power off at the breaker for the outside condensing unit, remove the two low voltage control wires from the contactor and tape them off. Can't have those wires live touching anything or the fuse will blow.
Install a new fuse. Flip the power back on to both units and turn the stat onto cool and drop the temp on the stat so it's calling through those low voltage wires to the condenser. Those wires, not being connected to the contactor and individually taped off and not having a chance of being a problem for the fuse, should not allow the fuse to blow.
If you do this and your fuse stays okay than replace the contactor that the low voltage wires connect to inside of the condensing unit. Remember, always turn all power off by way of breaker before and during any work.
* "Only you can prevent 'house' fires." ~ Smokey.
*ha! (to jb64)
Thanks.
Rhem Heat Pump low voltage fuse keeps blowing z4racer HVAC 3 02-29-2012 07:02 PM
New Bryant Gas Furnace - Fuse Keeps Blowing DIYerIT HVAC 2 01-08-2012 04:22 PM
Outdoor Christmas Lights Fuse Keeps Blowing mhp8982 Electrical 6 11-18-2011 10:10 PM
Trane XR90 keeps blowing fuse McTreez HVAC 1 11-01-2010 04:56 AM
Blowing fuse kenneth floyd General DIY Discussions 4 08-04-2009 12:27 PM
