05-06-2012, 01:13 PM
#1
ac keeps blowing the 5 amp fuse
replace the transformer,fan control board,capacitor,and contactor on condensing unit, once the fuse is replaced the unit will work for a couple of hours and then will blow the fuse again
05-06-2012, 01:48 PM
#2
Which fuse ? where is that fuse located ?
05-06-2012, 01:56 PM
#3
the fuse is the 5 amp fuse located on the control board on the air handler this board is for the fan
05-06-2012, 02:44 PM
#4
You need to provide more data. AC unit is ...... Window unit, Central air, hitachi ventless?
05-06-2012, 02:49 PM
#5
this is acentral,240 voltsunit , carrier 2 ton r 22 about 11 years old
05-06-2012, 02:50 PM
#6
carrier 2 ton central air split system 11 years old
05-06-2012, 03:21 PM
#7
Do you have any schematics, I, right now am fighting my own AC issues, my condenser unit has no pcbs, no fuses, and no transformers. I need to know at least model, mfg, to check online.
05-06-2012, 03:29 PM
#8
I'm Your Huckleberry
Fellow Houstonian? Welcome.
Thanks.
05-06-2012, 03:55 PM
#9
Hey Doc,
I'm a TX transplant. Love TX, never leaving.
05-06-2012, 04:22 PM
#10
Lived here my entire life. What side of town are you in?
Thanks.
05-06-2012, 05:16 PM
#11
Pinehurst
05-06-2012, 05:34 PM
#12
Doc,
My post is 4m205j, what do you think?
05-06-2012, 05:46 PM
#13
remove the stat off the subbase...disconnect the 24V wires out to the condenser at the condenser power up the air handler again with new 5A and then jump first R to G does it blow? then R over to Y does it blow?
05-06-2012, 06:01 PM
#14
Originally Posted by jb64
Pinehurst
That's way up north by Magnolia and Tomball, right? I used to work the Atascosita, Kingwood, Woodlands and surrounding areas last year. Company was in Spring.
Nice area up north but not being Houston City limits I've found a lot of code violations in homes out there. Not trying to scare you, just so you're aware. Get yourself a drain pan condensate float safety switch for your inside unit. It's required in the city but most homes out there don't have them. It'll protect your ceiling or floor from water damage and let you know when your a/c has a drain restriction. Down here you're drain will be flowing full time with the amount of humidity in the air.
They only cost maybe $20 and are very easy to install.
Thanks.
05-06-2012, 06:10 PM
#15
Doc, sounds like good advice, don't have to worry about the drip pan until I can run the ac, please check my post.
Thanks,
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
