Ac Issue Pls Help - HVAC - DIY Chatroom Home Improvement Forum
Old 06-22-2010, 08:25 PM   #1
ac issue pls help
in cool mode:
17 ohms across ac contactor low voltage coil
24 volts on both side of the contactor
blower fan comes on
is my contactor bad?
thx for any help...sweatin my but off
brokenhammer is offline   Reply With Quote
Old 06-22-2010, 08:26 PM   #2
when I push the contactor it fires up and runs til I let go
Old 06-22-2010, 08:45 PM   #3
An old Tradesmen
Rewards Points: 8,236
You don't read voltage on each side of the contactor's coil.
You measure for it across the contactor.
Probably lost common.
Old 06-22-2010, 09:39 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 398
Check the wiring to the outdoor unit for damage from weedwhacker, dog chewing etc. As Beenthere said you have 24 volts to the contactor but need it returning to the furnace/air handler with a return/Common wire which may be missing/damaged.
Old 06-22-2010, 11:53 PM   #5
This is really wacked out. I located a loose wire on the board, which apparently snapped off. It was one of the low voltage wires going to the condenser. I stripped it, and placed it where a fragment of the old wire was (removed it of course) and then I turned her back on. I heard the condenser kick on and clapped in joy, and then... I can hardly believe this, the furnace kicked on. Both the condenser and the furnace were trying to run at the same time. I turned off the gas at the shutoff and disconnected the HSI and the condenser is now running on its own. Next step is to chase down a trane xr80 wiring diagram.... unless someone may have some new ideas.
thanks for all the help!
Old 06-23-2010, 05:31 AM   #6
An old Tradesmen
What wire is on the W terminal.
Bathroom Remodel and Mold Issue jjump Remodeling 5 02-15-2010 12:56 PM
Interlock Paver Issue cbadrik Landscaping & Lawn Care 2 07-27-2009 07:29 PM
countertop installation - stove/oven issue diycarguy Building & Construction 12 05-04-2009 01:08 PM
HELP - with my breaker box. Interesting issue. LordX Electrical 75 02-23-2009 03:14 PM
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 01:34 PM
