AC Installation Question - HVAC - DIY Chatroom Home Improvement Forum
Old 04-08-2010, 11:54 AM   #1
The installer did not change the lineset tubing when replacing the AC unit. Previous unit was Freon based and new unit is R410. He said that he had flushed the line with nitrogen and a new line was not necessary. New coil was installed.
Comments please? Thanks
firozhirji is offline   Reply With Quote
Old 04-08-2010, 12:30 PM   #2
Did he install a filter / drier on the liquid line?
I suspect your suction line is undersized. Look at the size at the indoor and outdoor coil, you can see if the fitting has been reduced.
Is your existing lineset concealed?
Last edited by beenthere; 04-08-2010 at 02:57 PM. Reason: Removed link to another forum
User75130 is offline   Reply With Quote
Old 04-08-2010, 07:09 PM   #3
JohnH1's Avatar
If the lines are sized correctly there should not be any problem. I prefer to flush the lines with a RX11 flush. But in my opinion it is not as big of a issue as some think. Just my opinion.
JohnH1 is offline   Reply With Quote
Old 04-09-2010, 07:07 PM   #4
sktn77a's Avatar
Rewards Points: 392
Using the old lineset isn't a problem.
sktn77a is offline   Reply With Quote
batt insulation installation question tpagel Building & Construction 3 11-18-2009 11:08 PM
Hot Tub GFCI Grounding Question kearnak1420 Electrical 3 04-30-2008 05:48 PM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 09:10 AM
subfloor question for hardwood installation metrokarl Flooring 2 05-16-2007 08:37 AM
Wood Burner Installation Question? fisher501 HVAC 1 12-22-2005 09:29 PM
