Old 06-26-2012, 10:47 AM   #1
Question
AC/Heater Replacement Cost, Reasonable?
Job to consist of following, cost $3,740.00 :
  • Remove old and install new Comfortmaker 13 SEER Performance Series single stage 410A condenser M#N4A348AKB with matching case coil.
2. Adapt existing supply plenum to new coil.
3. Run new copper line set from condenser to coil.
4. Adapt PVC drain to existing location.
5. Adapt electric to new condenser. New fusible disconnect to be installed.
6. Set condenser at side of house and on pad.
7. Start system and check operation.
Job to consist of following, cost $2,905.00:
  • Remove old and install new Comfortmaker 96% gas furnace M#G9MXE1002116A.
2. Adapt existing supply plenum with coil to new furnace.
3. Install new standard 16x25x1 filter track on return of furnace and adapt existing return duct to new filter track.
5. Adapt electric and gas to new furnace.
6. Run new PVC flue to outside.
rob11g is offline   Reply With Quote
Old 06-26-2012, 01:35 PM   #2
Can't tell you what's a fair price in tour part of the world. My sister just paid$8500 for a comperable system. Will say a 16-25 filter is not big enough.
Old 06-26-2012, 01:38 PM   #3
If your installer can't size a filter correctly it's probably best to find another.
The Following User Says Thank You to Marty S. For This Useful Post:
rob11g (06-26-2012)
Old 06-26-2012, 02:18 PM   #4
I should have entered my location, my bad.
Old 06-26-2012, 02:19 PM   #5
New Jersey
Old 06-26-2012, 04:12 PM   #6
An old Tradesmen
A lot cheaper then I would be.
A 16X25X1 filter is a bit small for 4 tons. puts you at 577 FPM velocity, which is high for an air filter. that 16X25 size also prevents you from using even a low MERV pleated air filter, if you want good air flow and filtering.
The Following User Says Thank You to beenthere For This Useful Post:
rob11g (06-26-2012)
Old 06-26-2012, 04:16 PM   #7
I appreciate your attention 'beenthere'
I will ask the installer why he is using a smaller opening.
My current opening is 20x25X1
So the smaller one will make a difference?
Old 06-26-2012, 04:20 PM   #8
An old Tradesmen
Big difference. The smaller filter will not be able to stop as much dust as the pull on it will be that much greater.
There is a 100 sq in difference in filtering area between those filter sizes.
Addition "shell" cost per square foot - is this reasonable? ourzoo Building & Construction 21 12-20-2011 06:22 PM
What will be typical cost of roof replacement miamikk Roofing 10 09-11-2011 09:48 AM
Cost of boiler & cylinder replacement abaminog Off Topic 9 03-31-2010 08:05 PM
Replacement Window Installation Cost asr1715 Remodeling 1 02-08-2010 11:26 AM
Heil fan and motor replacement pinkertonpv HVAC 6 12-10-2009 10:10 PM
