Ac In Garage - HVAC - DIY Chatroom Home Improvement Forum
Old 06-12-2009, 11:38 AM   #1
ac in garage
i have a 2 car garage 26x24 and i want keep it cool what would be the cheapest route to air condition it. currently there are no windows or walk out door, just a 16' garage door and attic access above.
fordryan2005 is offline   Reply With Quote
Old 06-12-2009, 12:14 PM   #2
Is there insulation in the walls & ceiling?
Is the garage door insulated?
Where are you located?
How cool do you want it to be?
Easiest method is a window AC
I built mine into the wall
Size depends upon location, how cool you want it to be
I had a 24k AC that kept a 600+ sq ft open floor house cold
Old 06-12-2009, 01:29 PM   #3
You could also go with a PTAC or Mini split.
dac122 is offline   Reply With Quote
Old 06-16-2009, 09:53 AM   #4
i am located in illinois and yes the walls, ceiling, and door are insulated. i just want it cool enough to work in. for the window unit do you suggest just installing a window and putting the unit there rather than just cutting a hole into the outside wall
Old 06-16-2009, 10:00 AM   #5
Home Air Direct's Avatar
If you go with a "window" scenerio, use a "Thru the Wall" unit. They make regular window shakers that at specifically designed for the depths of walls, unlike most window units that are designed for shallow window wells.
Since you are in Illinois (as am I), are you planning on needing heat as well? If so, and you don't want to break your budget, check out the PTAC unit (think Hotel). That way you have both and will not be spending the bucks that come with a ductless. All that is required is a 42x16 hole in the wall and power.
Good luck.
Settle down! If you were that important, the city would give you lights and a siren for your car
Home Air Direct is offline   Reply With Quote
Old 06-16-2009, 10:22 AM   #6
I have found the wall units to be much more expensive then the window units. I've built 5 units into the walls at 2 houses & over 12 years they have all worked fine. I cut a hole, frame it out, install the AC & seal it. For the winter the are covered inside & out
We don't need a lot of AC up here. But we've had some hot spells where the AC runs for a wek at a time
You have about 624 sq ft of space - 8' ceiling?
So around a 14k BTU
You may want to go slightly larger in order to coll the garage down faster when you need it
Energy Star sizing sheet:
http://www.energystar.gov/index.cfm?...properly_sized
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
new double garage murray1426 Building & Construction 4 05-23-2009 01:11 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
Garage Door Install marly General DIY Discussions 2 11-17-2008 02:51 PM
