AC Fan Noise - HVAC - DIY Chatroom Home Improvement Forum
Old 06-21-2007, 01:20 AM   #1
AC Fan Noise
I replaced the motor in my American Standard furnace/air handler last winter. It's worked perfectly until today. There is an occillating noise coming from the motor/fan area. It comes and goes. I pulled the fan and motor and checked all of the mount screws, they were ok. There is a very small amount of lateral movement between the shaft and the motor body, but I seem to remember this was present when I installed it. Any ideas?
DeepHelmet is offline   Reply With Quote
Old 06-21-2007, 09:21 PM   #2
Eibwen
Intermittent vibration would be unusual... I would check the fan blade for debris, dirt buildup, or a missing balancing weight... Maybe take it out and spin balance it on a nail in garage.. I had one with so much dust on it one time it would rattle picures on the wall. Cleaned it off and it ran fine.
Sammy is offline   Reply With Quote
Old 06-21-2007, 10:35 PM   #3
That makes sense. I'll check it out, thanks.
GE side-by-side making a whining noise jkrodger Appliances 2 09-11-2007 03:45 PM
Fan Noise Ripbc HVAC 2 03-10-2007 03:29 PM
high pitch noise coming from oil line pingers7 HVAC 2 11-29-2006 08:41 AM
Noise when turning on water anywhere in the house pkulkarni001 Plumbing 2 04-10-2006 05:20 PM
Toilet making Noise DSHMSH Plumbing 1 12-22-2005 05:33 PM
