My outside AC fan motor is not working and I have tried changing out the capacitor. It will spin, however I believe the fan motor needs to be changed. It does not freely spin when i move the fan blade.
I have an old fan motor that works. Does anyone know if this will work? The top are the specs from the GOOD FAN I want to put in. The bottom are the specs from the OLD fan I am replacing. The HP is different (not sure if this matters) and the capacitor MFD. Also the AMP.
Any help is greatly appreciated!!!
GOOD FAN
EMERSON MODEL K55HXSWP-7983 HP 1/3
VOLT 208-230
RPM 825
INS CL B 60 degrees C AMB
AIR OVER CONT CAT NO 1875
HZ 60
AMP 2.4
PH 1
THERMALLY PROTECTED AUTO
MFG NO B09 C
FRAME 48Y
7.5 MFD 370 V CAP
OLD FAN MOTOR (BAD)
EMERSON MODEL KA55*XGWC-1986 HP 1/6
VOLT 208-230
RPM 825
PT NO 243463-03
INS CL B 40 degrees C
HZ 60
AMP 1.1
PH 1
THERMALLY PROTECTED
MFG NO K58 2
AIR OVER CONT FRAME 48Y
5 MFD 370 V CAP
