Old 02-28-2007, 01:02 PM   #1
Unhappy
ac evaporator question
If you have that orifice pin in the small line on the evaporator coil do you need a thermal expansion valve as well on a central air evaporator, mine appears to only have the pin, no valve?? should I be installing one.
thank you
paddd is offline   Reply With Quote
Old 02-28-2007, 03:29 PM   #2
you have a "fixed metering device" and that is adaqute.
harleyrider is offline   Reply With Quote
