-   -   AC don't work no more (http://www.diychatroom.com/f17/ac-dont-work-no-more-9670/)
ocoee 07-06-2007 01:05 AM
The outside fans works
The coils get cold
The fan does not blow inside
If I put my ear up to the air handler I hear what sounds like an electric motor trying to run even when the unit is turned off at the thermostat
When I turned it on with my ear to the air handler wall I hear what sounds like a kids boom car at a redlight with the windows rolled up.
At first I thought it was the next door neighbors rap music coming through the pipes
Any clues
The 24,000 BTU unit iwas installed by the previous owner in 98, small house
redline 07-06-2007 08:15 AM
Do you have access to the air handler?
(sounds like the blower motor needs to be replaced)
ocoee 07-06-2007 08:24 AM
That's what I was figuring
The air handler is one of the closet model
with the panel in front, just a few hex heads in the way
Seems simple enough, but that's what I said about the injection pump on my truck
Any hidden hoops to jump through
The air handler is on a separate breaker and I have taken out the main disconnect at the unit so that end is easy
MechanicalDVR 07-07-2007 12:32 PM
There is a relay to bring the motor on, if the motor has power and doesn't start it could be a bad capacitor, if there is no power at the motor leads it could be the switching relay or the thermostat not bring on the fan.
ocoee 07-10-2007 06:10 PM
Ok
I don't have any electrical testing tools yet so I have done what I could
The aforementioned bass thump coincides with the motor trying to turn
the fuse is good
I can not find a reset switch but there is a remote disconnect that looks like a very large fuse I pulled it out and waited a little before plugging it back in
When I disconnect the thermostat the thumping and meager attempts of the fan to start all stop so I believe that the thermostat is good
This is a carrier unit if that matters
MechanicalDVR 07-10-2007 11:18 PM
Call in a pro, you most likely need a blower motor but it should be properly diagnoised.
ocoee 07-11-2007 08:19 AM
Too many other expenses. no money for a pro
That's a defeatist attitude anyway, I have fire insurance:)
I'm just going to start with replacing the relay, capacitor and then the motor if necessary.
Most of that stuff I can get either free or cheap
MechanicalDVR 07-11-2007 09:17 PM
Do you have life insurance too?
