Ac Contactor Replacement And Run Capacitor Discharge - HVAC - DIY Chatroom Home Improvement Forum
Old 04-27-2009, 05:40 PM   #1
ac contactor replacement and run capacitor discharge
Hi all,
I have a rheems ac unit. I am thinking of replacing my ac contactor on the condenser outside though it is still working fine (been there almost 9 years). I understand I must cut off 240 volts and turn off thermostat for it before I start.
My question is whether simply use insulated pliers to pull off all the wires to the contactors (lines and terminals) is good enough ? As on the terminal side, it has connected to a run/start capacitor or should I discharge the cap first before working on the contactor replacement ?
If need to discharge cap, can I do it with all the wire-in-place using a big insulated screwdriver or I have to disconnect the wire first ?
Thanks all so much in advance.
rheems88 is offline   Reply With Quote
Old 04-27-2009, 09:16 PM   #2
At rated current, if the voltage across the closed contacts is less than 30 mV they're good. Above 100 mV, bad.
Don't short it with a screwdriver. Grainger sells a 15k, 2w resistor for this purpose. Buy one at Radio Shack.
Old 04-28-2009, 11:07 AM   #3
thanks for your reply. I will use resistor for this, but can I do it with all the wires in-place ? or even better, can I not touch the cap at all (simply remove the connector and replace the contactor and put the connector back) ?
thanks again.
Old 04-28-2009, 11:15 AM   #4
thanks again.
Yes, just tape over the cap terminals if there is a chance of touching them.
You know, anytime you mess around with something that's working [or not] there is a non-zero chance that something else will stop working, either because of operator error [like dropping a conductive tool into the works] or because of some baffling problem that suddenly springs up and that may or may not be related to your work.
I wouldn't mess with this unless you are having a problem, especially not if your relay contacts pass muster. Monitoring parts health is less risky than replacing parts.
Old 04-28-2009, 11:55 AM   #5
thanks a lot for your time and replies. Those are very wise advice. I will take your advice and stay alert on it (rather than messing with it).
